R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Gas vs diesel R class ?
Old Dec 23, 2018 | 11:49 AM
wrightbenz's Avatar
SL55 SLK 320
I am looking at an R class to replace our not so great Lincoln Navigator.
I see quite a few of the 320 cdi and the 350 diesels if I look nation wide.
Lots of information bad talking the Diesel engines but I am a serious DIY guy and it may be a better fit for me.
I do not want to work on the thing everyday or anything but if it’s a matter of resolving a few issues and then I’m good that’s fine.
Old Dec 23, 2018 | 12:35 PM
efzauner's Avatar
2005 C240 2011 R350
stay away from old used diesels. Its not about resolving a few issues. It is major problems like leaking oil coolers, injectors, glow plugs, particulate filters, intake valves, turbos, oil getting everywhere. etc all very expensive and time consuming to fix. Plus they make noise making you grind your teeth saying WTF everytime. I have had an r320cdi, colleague had an R350 blue tech. both had $10K repair bills.. luckily mine where where under extended warranty. His weren't, he drives an Infinity now!
Old Dec 24, 2018 | 12:18 AM
wrightbenz's Avatar
SL55 SLK 320
sounds about like what I am finding written elsewhere.
There does seem to be a lot of sprinter fans out there with lots of miles on the diesels. Some people also prefer the cdi over the bluetech. A bit less complex from what I have read.
Old Dec 24, 2018 | 01:27 AM
rustybear3's Avatar
2019 Dune Silver Metallic E-450 Mercedes Cabriolet NEW Mercedes 2020 GLC300 graphite gray SUV
Plus the cost of diesel fuel is almost another dollar a gallon.....
Old Dec 31, 2018 | 03:48 PM
lkchris's Avatar
'10 CL550, '12 GL550
I’ve had a 2007 diesel GL—same engine—from new and have experienced few problems. I wouldn’t get one of these newer than 2008, as beginning 2009 diesel exhaust fluid is required, which eliminates the spare tire and saddles you with run flat tires.
Old Jan 5, 2019 | 03:29 PM
BenzBallin's Avatar
R350 2008 4Matic Gasoline
Any inputs om the GL320 Diesel ? Was looking at some 2007-2009 ..are they reliable ?
Old Feb 11, 2019 | 09:27 PM
wrightbenz's Avatar
SL55 SLK 320
seems like some like them some don’t. Of the cost of fuel were equal I think I would take a shot at a diesel but at the moment Diesel is more than regular fuel.
Old Feb 12, 2019 | 12:54 PM
chassis's Avatar
2017 GLE350 4MATIC
In the US, the value proposition for a diesel consumer passenger vehicle is not there. Speaking from recent experience and significant travel to Europe, where diesel is viable.
New diesel car purchase price in the US extracts the financial value of improved fuel economy, net of price differential of diesel vs gasoline. So, at this level, no advantage to the consumer. Then comes higher maintenance costs (oil and filter) and lower reliability (DEF, DPF, EGR and connected hardware), which is the case for Mercedes, BMW and Volkswagen diesel systems in the past 10 years, in the US market.
I am a diesel proponent, however the options available to consumers in the US are less economically valuable than gasoline powered vehicles.
I restrict the above comments to light SUVs and sedans. Diesel light, medium and heavy duty (commercial) trucks are a separate discussion.
