Torque setting for rear caliper bolts
I am about to replace my rear pads and rotors on my 2006 R350L. Can anyone tell me the torque settings of the rear caliper bolts? (18mm self-locking bolts - caliper support to wheel carrier).
My R350 is equipped with solid rotors.
Thank you in advance!
If you purchased new bolts, see the attached guides. Basically 60nm then 45 degrees more.
If you reuse the old bolts... your guess is as good as mine!
