r500 alternator replacement procedure?
Can you get it out underneath? Thanks for any help, need to get this back on the road.
There are clearance issues with the removal of the alternator in the V8 w203. I contemplated several different solutions including removal of the water pump, raising the engine, and removing the fan shroud assembly. The water pump would solve the interference directly, but be a total pain in the ***. A quick trip to Mercedes taught me that my car may have two different pumps (with differing gaskets) and both gaskets had to be ordered. I needed the car for work at 6 am Monday morning so that would leave me channeling my inner MacGyver. The thought of attempting the salvation of the present gasket while removing all those little bolts was frightening so I shelved that idea. Next thing considered was raising the engine to allow the alternator to snake underneath the water pump bracket. I didn’t do this because I had just invested in fresh motor mounts and didn’t want to upset their seating. I would be lying if I didn’t say lifting the engine was also imposing enough to scrap it right away.
The solution I settled on was one that I found mentioned with regards to the w210 E55 guys. The removal of the fan and fan shroud allows acceptable room to maneuver the alternator out of the engine compartment. Also, a benefit over the w210s, the C55 doesn’t require any specialized tools for removing the fan. Unfortunately, I didn’t take more pictures as this was a ‘learn as you go’ operation.
With the serpentine belt and all coolant lines in the way removed (it pays to siphon off some coolant first), you can remove the fan itself. It was held on with four Torx bolts; small, T-25 if I remember correctly. Maneuver it slowly up and out of the engine compartment. The water pump pulley is the only really tight squeeze here. Next, you are on to the fan shroud which is a bit more of a pain.
My method was a little shade tree with regards to loosening and flexing the front engine compartment sill to allow the fan shroud to be removed. You do this by removing two silver bolts on either side, pictured:
Then I took off two little 8mm bolts in the center to minimize undue stress on the grill. These circular black plastic plungers hold the radiator centered, I removed these and unhooked the little arms to keep the radiator from working against us. Here’s where another pair of hands is quite helpful, I was lucky enough to have my Dad give me time away from his ’41 Chevy project.
There is a large electrical plug at the bottom driver’s side, extremely accessible from under the chin of the car. Remove that first then look for clips on either side of the fan shroud that will release it from your radiator. With it disconnected, carefully walk it up and out of the engine compartment making sure not to get stuck on wiring on the driver’s side and AC lines on the passenger side. The engine compartment sill does need to be pulled against- do so carefully and evenly. There are some very close clearance spots around the water pump pulley and the oil filter area. Be sure to come up with it evenly to avoid getting caught up. Patience and good light are important to avoid any unnecessary collateral damage.
Above is a picture of the cavernous room you have with the fan shroud out. Do be mindful of the exposed radiator! There is zero protection and the alternator is quite heavy. The room made from the fan shroud removal is enough to get the alternator out without removing the VR and cover from the back. I would leave all that intact on the alternator to protect it for a later rebuild.
*Remember to move the small sleeves in the upper and lower alternator mounting points to allow for the new alternator to slide in easily. These little golden sleeves, not witchcraft, were why the old alternator needed prying out once you removed the two bolts.
Good luck and safe travels!
I could SWEAR both the black and the red wire were connected to the same post on the alternator I took out, but I didn't take a picture. Does that seem right?
The other post is not used - it doesn't have enough thread to even get a connector/nut on it.
I'll post my findings, unfortunately without pictures - this was a little bit of an ordeal to get done.
LONG story short, I was able to get the alternator out after remove the center crossmember, which required disconnecting the passenger side hood latches. The cables for the hood latches are captive inside the crossmember. Once that is loose, the radiator has a LOT of play. After disconnecting the top, bottom, and pump coolant hoses, I had enough play in the radiator to move it forward a couple of inches with a good tug. This was enough to get the alternator out.
Oh, also had to remove the front part of the under-engine cover, and the intake hoses up top.
Getting it loose requires a prybar - the brass sleeves in the bracket will keep it tight even with the bolts out. Once out, those brass sleeves have to be reset. I found this post on a Chrysler crossfire forum - this technique worked:
My wiring to the alternator had so little slack in it that I needed to hang the alternator first and then attach the wiring from underneath the car. I couldn't get it hung from the top with the cables already attached. After I put everything back together, I refilled about a gallon and a half of coolant before it went back to full. I ran it for an hour with the fill cap open and the heater on full, massaging hoses to get the air out.
Also, I never could locate the hole for locking the serpentine tensionser, not with the fan in the way. So I had to put the belt back on while keeping the tensioner loaded with a socket. Not too bad, but a little nervous that something would slip and break a finger.
That's it. If anyone has questions I'll try to clarify. In general - next time I think I'd be willing to pay for 1.5 hours of mechanic labor for this, which is what I was quoted. However, the markup on the part itself was over 2x what I could find it online for the genuine new Bosch part, which is what made me think I would rather do it myself. So I saved some money, but it took me WAY more time than it was worth to figure out the extraction. Reassembly was a lot faster, of course.
