R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Timing code P001685 2012 R350 Need Help!!!!
Old Nov 21, 2019 | 04:12 PM
dizzylish's Avatar
r350
We have a 2012 R350 with the 3.5 engine. Had the rattle noise for a timing chain tensioner failure. We changed out all 3 tensioners. After putting if back together car runs smooth but will set code P001685 The position of the intake camshaft cylinder 1. is implausible relative to the position of the crankshaft, There is a signal above the permissible limit valve. I am 99% sure the timing didn't jump. The car runs smooth but will set the code as soon as we start the car. We swapped out magnets and sensors and still returns. Anyone have any ideas, At this point, I am lost. Also I really cant find anything making sure the timing is on.
