DTC 9095 Circuit 15R Relay Problem (Left Turn Signal Bad)
9095 The output of component F4kR (Circuit 15R relay) has Short circuit to positive. This is the only faulty code after I erased the saved one from rear SAM. No other faulty symptoms from rear SAM.
I replaced the relay but didn't work. I swapped the turn signal socket from right to left. No luck. Can anyone help me figure out what the real problem would be, rear fuse box or rear SAM?
Neck-Pro head restraint (SRS Warning light) has been a problem for a couple of years.
So my questions about P9095 are:
1. Would the rear SAM be a problem?
2. If not, can 2007 R350 rear fuse panel (A1645402372) be compatible with my 2008 r350 (A1645403072)? Do I need to reprogram after replacing rear fuse panel or just simple swap?
I love this car, but it starts to ask more money for the maintenance, which may cost me thousands of dollars for several issues.
One by one at this moment, I need a help to fix rear left signal light first.
Thanks so much for help and advice.
Chris. vin 4JGCB65E08A066239
