R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Motor mount /engine mount replacement help needed
Old Apr 23, 2021 | 06:21 PM
ODIOUS's Avatar
None
I have a 2011 R-350 4-matic on jack stands right now. Can anyone tell me or post instructions on how to the driver's side mount out? I have tried lifting/shifting the engine. I simply can see how the mount can get past the front differential.
Attacking from above would require me to remove the exhaust manifold and the steering linkage i think....which cant be right for a simple mount like this.
Thanks in advance!
Old Apr 24, 2021 | 08:52 AM
virgisr's Avatar
Mercedes R320L CDI 4MATIC 2007
Thanks in advance!
You did not mention which mount. as there is front and rear ones.
Here is what i have found. hope that helps. Attached front ones instructions. If there is anything different on these instructions and your car, probably would be best if you provide your VIN.
Old Apr 24, 2021 | 08:54 AM
virgisr's Avatar
Thanks in advance!
an update regarding my previous message:
at the rear there is a crossmember mount, which probably you are not after. So first message should help you out.
Old Apr 25, 2021 | 11:31 PM
ODIOUS's Avatar
None
Thank you virgisr!
I was able to get this out the next morning by removing the AC compressor and the power steering pump/resevior and shifting the lifted engine to the side as much as possible.
It didn't occur to me to remove the engine supports but Im not sure how I would have done so with so little room to maneuver.
I couldn't even see the mounts or supports clearly so even if I had to do it all over again the right way it would be pretty tough.
I read a webpage where someone did the mount change on a 1st gen R-class and didn't need to remove accessories but that's definitely not the case with the gen2.
Hopefully this will help other's down the line.
