R350 oil change by suction
2010 R350 Blue Tech
I was told by a mechanic thatmy oil needs to be sucked out and then replaced. Most garages do not have the right device. Suggestions?
https://www.amazon.com/dp/B0836GH3G7...W9E7RP8RXR3RA6
Get one of these. You won't need to lift the car as the oil filter is up top as well. You can do it all in your driveway/garage.
naw.. R350 has almost 9 liters of oil. that thing you propose is only 6.5l.
I have one similar to below and it still takes 15 or more minutes to suck out thru the thin tube. You dont want to be pumping manually for that time
Also. MB have a specific oil tube size and there are special MB extractor fitings that fit directly My C240 can be extracted full with this. R350 can be sucked 90% with this, then the tube.
this is the real deal!
https://ca.jmesales.com/john-dow-pro...BoCEEwQAvD_BwE
Hi guys,
I always heard about this oil suction thingy but never thought it was necessary. Do you confirm there is no other way to change the oil, such as by letting it flow?
Um you can change the oll the normal way from the bottom but you may have to remove the plastic bottom cowling.
Honest get one of these ... you will ask yourself why you waited this long.
I used this, on my 2011 R-350 several times. It seemed to work fine, I'd have to pump it up a couple of times during the process. I'd move the line up and down a bit until it was sucking air at the end.
I have done that on mine a couple of times now. What i am using is a simple oil pump, driven by 12V from car battery. On R class you can hook it to jumps start points. Bought it from some shop for 15GBP. Works well. It comes with transparent hoses. Drop it into any container and thats it. Surely through google search you will find one to buy.
