2006 R350 cylinder #2 misfire, stumped.
2006 R350 cylinder #2 misfire. Was running perfect, stopped for gas, restarted and was running rough and check engine light came on. Turned off n restarted and ran/drove fine for 15 min till I got home n started missing again. Shut off n restarted and ran fine. Done this several times until it no longer worked. Pulled code p0302 so swapped coils, no change. Swapped plugs no change. Assumed it was injector so new injector, ran great for 5 minutes then back to square one. I even swapped injectors around just in case. Definitely have power to injector, checked all wiring, o2 sensors, cats, coils, cam sensors, plugs. I have erased code p0302 after every parts swap/change and upon startup it runs fine for a minute then very slight idle drop and back up then check engine light starts flashing then stays on n code sets. Sometimes even with this code present engine revs smooth, other times I can feel mis.
I know my way around a cars pretty good so not a newbie but this has got me stumped and at total loss.
Garaged since new, I’m second owner and garaged w/130,000 highway. Last year complete MB intake, p/s pump, a/c clutch, both batteries.
Any ideas would be VERY MUCH appreciated BESIDES taking it to dealership.
Thank you, Paul.
spark plugs, doesn’t matter if they look good
coils and boots
cam position sensors all 4
cam magnets all 4
crank position sensor
mass airflow sensor
coolant temp sensor
oxygen sensors all 4
If the above doesn’t help do a compression test. Probably a good idea to check compression when replacing the plugs, coils and boots.
