R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
2006 R350 trunk latch not closing
Old Jul 29, 2022 | 12:35 PM
shawninvancouver's Avatar
R350
this is not a power liftgate, just the power motor on the latch that closes the tailgate closed. it was not closing the trunk tight and i needed to slam it closed.. I have replaced this before and it worked fine.. this time i have tried three new motors and same problem.. it wont close it,, it has power to unlock it as when i pull the handle the motor moves... any ideas ?? is there a fuse for the closing of this??? any help would be great
Old Jul 29, 2022 | 12:47 PM
R350
Anyone have any ideas???
Old Jul 29, 2022 | 01:01 PM
R350
does this close by a magnet? or is something not aligned ?? someone says it could be the SAM system???
Old Jul 29, 2022 | 05:27 PM
R350
anyone have any ideas? i was told it could be the sam.....
Old Jul 31, 2022 | 01:35 PM
R350
can anyone help me here????
power close not working after trying three new motors.... what else can it be??
Old Aug 1, 2022 | 04:03 PM
Trampas's Avatar
2011 MB R-350
Does it close if you flip the latch inside the rear window, and close the rear liftgate manually? I have a 2011 R350 with a working power rear door and I end up flipping the handle and closing it myself 90% of the time anyway. If it works fine with manual closing, I would give yourself a mental break and not try and chase down what could be bothering 16 year old Benz's rear power liftgate.
Old Aug 1, 2022 | 04:10 PM
R350
this is not a full power lift gate that lifts it all the way up.. my problem is the latch actuator that pulls the trunk tightly closed.. i have tried 3 latch motors and none will pull it tight closed...
