R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
windshield washer pump electrical module?
Old Jan 21, 2024 | 10:42 AM
efzauner's Avatar
2005 C240 2011 R350
Hello
my WW pump fittings are leaking so going to fix that
but I cannot find what the electrical module is? None of the ALLDATA diy manual have anything pertaining to this part/
I presume that
1: is hose to front washer nozlzes
2: is front and rear washer pump
3: is headlight washer pump
4: Found it... see below. its the heater... but question remains how do you direct flow front to back? Anyone know how this works?
Old Jan 21, 2024 | 11:29 AM
efzauner's Avatar
2005 C240 2011 R350
Found the electric circuit.. so #4 must be the heater... same color code wires. seems like a small heater... additional description says its the washer hose heater. There must be nozzle heaters also.. but I have not found them!
No nozzle heaters. I had to clear out a blocked nozzle and there is a heating wire that is inside the rubber hose!
