First start of day engines make rattle sound
Subscribe
Mar 22, 2024 | 02:18 AM
My 08 R350 makes a load rattle only when I start the car for the first time, subsequent starts the same day it does not rattle. The sound last for just a couple seconds. Thoughts?
Reply 0
Mar 22, 2024 | 07:35 AM
Quote: My 08 R350 makes a load rattle only when I start the car for the first time, subsequent starts the same day it does not rattle. The sound last for just a couple seconds. Thoughts?
The first thing that will come to everyone's mind will be a stretched timing chain. Rattle on first start is the classic symptom. Assume you car is gas and not diesel?
Search the forums including W164 and X164 and even W211. All used the same engines. The M272 is well known for this issue prior to mid 2008. See the attached bulletin from MB that specifies the engine number ranges of engines that are impacted by the balance shaft issue.
Reply 1
Apr 3, 2024 | 05:06 PM
The rubber ring needs to be replaced
GENUINE MERCEDES Engine Oil Pump O-Ring 0149973148 / A0149973148 | eBay
Reply 1
Dec 22, 2024 | 02:53 AM
Is this something that be replaced at my home with no lift?
Reply 0
Dec 31, 2024 | 02:17 PM
Why would the pickup tube seal ring cause a rattle at startup? Timing chain and tensioner I understand, or something in the oil filter causing it to leak down overnight. Or do you mean the seal inside the pump?
Sump off either way I guess. But why that part and not the chain?
Reply 0
Dec 31, 2024 | 04:18 PM
Quote: Why would the pickup tube seal ring cause a rattle at startup? Timing chain and tensioner I understand, or something in the oil filter causing it to leak down overnight. Or do you mean the seal inside the pump?
The seals fail and cause a lack of oil pressure on start up.
Reply 0
Subscribe
Currently Active Users (1)
