R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Where to buy brake pads and rotors
Old Dec 26, 2024 | 06:27 PM
kmccarthy16's Avatar
MB 1982 280 SL. MB 2008 R350
I need to replace my brake pads and rotors for my R350.
Where is a good place to purchase brake parts?
Old Dec 26, 2024 | 08:40 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
SIMPLE AKEBONO CERAMIC UPGRADE
Rule No1: buy reputable brands at trusted locations. Not Mercedes parts on eBay...
Best advice would be AKEBONO ceramic pads + Zimmerman rotors and related parts on FCP-Euro with free lifetime replacement.
Sometimes Mercedes sells genuine parts cheaper than FCP does... meaning shop a little!
Old Dec 27, 2024 | 04:37 PM
Thank you
Old Dec 31, 2024 | 02:07 PM
dogshome's Avatar
R350 CDI
The R class is a heavy girl and the brakes are not huge. I find them effective for normal driving, but if hauling down from high speed, or hurtling around B roads, not so great. I've had no trouble with discs from various manufacturers in the past on numerous other cars, but always avoided cheap or unknown pads. I've also usually fitted the biggest standard discs where there was a cheap upgrade (Saabs mainly). That doesn't look possible for the R, unless you have a lot of money and an AMG where it would be worth it.
When it's time to do the big lump that is my R class, both the Zimmerman and Akebono look reasonably priced, so I will bear this in mind
Old Dec 31, 2024 | 02:17 PM
I priced the parts through FCP-Euro and then called my local MD dealership. The parts were more than double, and the parts guy couldn't even tell me if the pads were ceramic or not.
Old Dec 31, 2024 | 02:39 PM
TimC300's Avatar
Pads and rotors are something I made sure to buy from FCP for the warranty. I went with Zimmerman rotors and like the silver color they come in.
Old Jan 1, 2025 | 03:19 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Your R350 probably has the 325mm front rotors like the ML350. If you hunt around youll be able to find the ML550 rotors and calipers that are 350mm and I assume, the same for an R550. These can be changed in to your R350 and are a reasonable upgrade. Check your calipers and usually the size of the fitment is cast into the caliper housing and/or the bracket that holds it all together.
The AMG calipers are 375mm and expensive and hard to find.
