R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
07 Mercedes benz 350 cranks but will not start
Old Jan 30, 2025 | 03:01 AM
Fall20256$'s Avatar
R 350
I have a mercedes r350 that will not start. The only code is p0118. Issue statted after I changed cam shaft position sensors and cleaned motor.
Old Jan 30, 2025 | 03:29 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Why did you change the sensors? Was there a fault or preventative maintenance? How many miles on the car?
P0118 is a Temperature Sensor Code. Any chance you dislodged the connections when cleaning?
Old Jan 30, 2025 | 03:38 AM
BlackML550's Avatar
See this post which has good information and pictures for the temperature sensor the same engine as your car. Look to the W164 and X164 forums. Many more members than R series that were low volume and they are essentially the same cars.
https://mbworld.org/forums/m-class-w...ocation-2.html
