Service D
- Oil and filter change: This is a standard part of all Mercedes service packages.
- Fluid checks and replacement:Includes checking and correcting all fluid levels, and often replacing brake fluid and transmission fluid and filters.
- Filter replacement: Engine and cabin air filters are typically replaced.
- Brake system inspection: A thorough inspection of the brake system, which may result in the replacement of pads or rotors.
- Spark plug replacement: This is often included for gasoline engines.
- Comprehensive inspections:Technicians will inspect the suspension, drivetrain, and exhaust systems.
- Diagnostics and road test: A full diagnostic test and a road test to ensure everything is functioning correctly.
Thank you, I already did everything on the list this fall, including changing the Brake Fluid (right rear came out as black gunk) and I did a transmission flush with filter change in the spring.
Only fluid I have not changed is for the servo.
Anyone have specs on the servo fluid, and is there a filter in the tank/system for the servo on these? Just regular ATF?
I realized after it was a diesel car. I ment glow plugs. Spark plugs would be something. I actually forgot the R class even had a Blutech and CDI model.
Friend of mine had a Jeep Commander with the same engine.
265 hp in the highest power version, mine, luckily does not have AdBlue//DEF. It is also soft tuned to 305hp/700nm. Happens to be the same power I had stock in my old Truck, a 2003 GMC Sierra LB7 Duramax, with 6.6l of izuzu power. It was tuned to 460hp/1150nm.
The car really pulls with this engine.
It downloads the factory firmware and they modify it with the tune. They can also disable EGR via software, or remove the DPF (you can physically remove them afterwards without any errors)
It also tunes the gearbox at the same time.
