S/CL-Class (W140) Coupe 1994-1999: S500 Coupe, S600 Coupe, CL500 Coupe, CL600 Coupe
keyless entry not working?
Old Oct 8, 2004 | 01:08 PM
rstanaker's Avatar
'98 CL600 -Euro model
Any ideas regarding this problem aside from changing the batteries in the transmitter?
'98 CL600
also, will the new smart keys work with the '98 '99s??
thanks!
-Rob.
Old Oct 9, 2004 | 04:59 PM
market000's Avatar
1999 CL500; 1992 500E:1991 560SEC
You can check the batteries in the remote by holding the unlock button down for a few seconds. If you can see a red light flash in the small red plastic window adjacent to the key swivel point the battery should be good.
I don't think the smart keys used in the newer body style (post 140 coupe) will work.
Old Oct 29, 2005 | 10:28 PM
darky_minded's Avatar
cl600
i had the same problem see there is a kind of a vacume pump or a compressor under the right side back seat the problem is from it you can fix but it would be better if you change it
