Oil change FYI
Old Jun 12, 2023 | 08:31 AM
wheatswake's Avatar
2017 S550 coupe, 2013 E550 coupe, 2008 Tahoe
Oil change FYI
So I decided to see how much additional oil I could get out once the dripping started from the pan drain. I put a 250ml beaker under there and filled it up twice over an 8hr period. I know most are not going to do this but goes to show that quick oil changes leave a decent amount of old oil behind to mix with the new oil. Also found my swaybar and an electrical connector a little wet on the pass.side (car is a 2017 at 26K miles), tried to trace it down but it was not very apparent where it was coming from. Going to take it in under CPO warranty.
Old Jun 12, 2023 | 05:23 PM
JimWilder's Avatar
2022 SL 63; 2017 S-550 Cabrio; 2013 SL-550
I like how meticulous you about your car. I have the same yar and miles, but Cabrio. Let us know what you find on the leak.
Old Nov 16, 2023 | 09:24 AM
wheatswake's Avatar
I suspect the leak is coming from the cam shaft plug cover (cylinder head expansion cover) on the back of the head (passenger side). Part# 00099866590 , $6.89 each on amazon. I have not replaced it yet but will chime in when I do. There are a few videos on youtube about it.
Old Nov 22, 2023 | 01:01 PM
SpiderAce's Avatar
S63 AMG Coupe AMG GT55
can i join your club!?
Same year, same mileage!!! SAME OCD behavior and live in the same State....(not state of confusion.... rather Texas) Actually one reason I try to do a more frequent oil change schedule is the amount of residual oil that's left.
