shock absorber advice
560SEL
what are the best shocks to go with when looking for good comfort but superior handling
monroe reflex or blisten sports
or something else!!
or something else!!
Originally Posted by m117968
Monroe is Crap... Bilstein or Koni's.
Jonathan
Jonathan
Go for the Koni's.
Koni Specials shock housings are about 97$ for each corner.
If that's too much, KYB has their Gas-A-Just shock housing for 32$ for each front and 31$ for each rear.
Most commonly when people get new shocks OR springs, they get both. Saves money in labor. For springs you can get
Eibach Pro-Kit Spring set - $303
or the
H&R Sport Spring set - $266
Personally I like the Eibach one more, but I use the H&R Sport Spring kit in more cars.
All the items I mentioned should fit a 1990 560SEL.
'99 C43 AMG
Bilstein SP (sport), just put a new set on my car and love them. I had them on my old C280 and 190E too. The SP's are also designed for lowered suspension systems so if you put on lowering springs you won't have any problems.
1 Post
1987 300SDL aka the "Money Pit"
Their really is no reason to replace the springs unless the car is saging or you want to lower it. Replacing springs is a heck of a lot more work. Changing shocks on a W126 is extremly fast and simple.
Bilstein comforts are my favorite. These are not sports cars, I don't want a stiff ride.
560SEL
well i do care abt little bit of comfort but am more concered abt handling with tis car.. when i need comfort..i drive another 560 with hydromat suspension
96 S600 Euro, 91 560 SEC, 88 300TE, 87 560SEL, 86 560SL, 80 280SE, 64 Austin Healey 3000MIII
They don't make sports for the 126.. And you can use HD's or comforts on lowered cars w/o issue.
Jonathan
560SEL
tried blisten, tried monroe... must admit blisten are good shock but too stiff for a car designed to be more luxry and less sports
while im concered with improving handling.. im sticking to fine line between comfort and handling.. after all im not gonna use the car on track or something..
monroe reflex felt better.. somewhat the honda accord 2004 - 2005 like ride..soft and smooth at cruising speeds.. stiff and more road holding at acceleration and highway speeds..
tho its well known that monroe's will not last more than two years but hey are also 3 times cheaper than blisten..so if blisten lasts 6 years ..monroe will need replacement three times in the period of 6 years.. but hey u get new looking parts on ur car chasis
