How to stop Interior squeeks / noises
Hello,
I'm new here, wondering if you guys can help me.
91 560SEL
I notice the interior makes a lot of noises when I go over bumps and cracks in the road, and also when I brake. It seems the door panels are the main problem. When I drive over a bump, the bottom of the door panel comes into contact with the door sill (or scuff plate, the step up cover) and it makes a really bad squeeky noise. After a while, this can get pretty annoying. Does anyone know how to fix this? I removed the door sill to test it out, and the squeeks were gone. Please help..
91 560SEL
Several MB's Superperformance MK III Cobra
Originally Posted by zodiax
Hello,
91 560SEL
91 560SEL
This will last for about 3 months and you will have to do it again. I know that it is only temporary but at least it gets rid of the annoying creaking.
Thanks for the replies...
I will buy this Lexor Leather Conditioner as you said.... but I don't understand how a leather conditioning spray can have an effect on a plastic door sill? Does it make it soft or something?
Let me know, THANKS!
Okay..
So I should apply the spray to the surface of the door sill?
Should I apply any of it to the bottom of the door panel?
Thanks again..
Thanks again..
Originally Posted by schwarzwagen
I applied sticky felt. I would recommend that over sprays and such, the felt only needs to be reapplied every 2-3 years of daily operation.
Vaseline works like a charm!
I had bad squeaking at the left rear door, where the bottom of the panel contacted the door sill. A bit of vaseline along the bottom works very well to silence that.
