S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
1984 500SEL Engine Stalled
Old Dec 27, 2005 | 09:30 PM
Jesse923's Avatar
Hi,
The other day I was driving my 1984 500SEL and the engine just shut off. The car shuddered first and then stalled. I still had control of the steering so I pulled it over to the side of the road and had it towed... There was no smoke or anything, engine just stopped working. Now when I try to start it the engine won't turn over. I checked the battery and gas and it is fine, any clue what could be causing this problem?
Wanted to check to see if it was a easy to fix problem before I went to the trouble of bringing it to a garage. The AAA person and a garage said it may be a fuel pump, but dont want to replace it without checking it out with you guys first.
I should also mention that the car was shuddering a little bit while it was cold for about 2 weeks previous.
Thanks for your help!
Old Dec 27, 2005 | 09:45 PM
jello2594's Avatar
2004 CLK500, 78 6.9,
Diagnosing a malfunctioning car over a message board is a great idea!
I'll put 10 bucks on the fuel pump or fuel pump fuse.
Old Dec 28, 2005 | 07:11 PM
Jesse923's Avatar
Add. Info
I should also mention that before this breakdown, the car had high hydrocarbon and carbon monoxide readings. Does this lend you all to further support the diagnosis of fuel pump, or does this lead you to think it is something else?
Thanks!
Jesse
Old Dec 29, 2005 | 09:53 AM
elbe's Avatar
2004 S500; 1991 300SL
By the comment "Now when I try to start it the engine won't turn over" what do you mean? It won't turn over by itself or the starter won't turn it over?
Old Dec 30, 2005 | 11:04 AM
Jesse923's Avatar
I mean that it seems like the spark plugs fire and the pistons go, and the belt turns when I turn the key, but the engine won't start up.
Jesse
Old Jan 8, 2006 | 09:11 PM
HLG600's Avatar
2009 SL63 AMG
If the spark plugs fire and the belt and pistons move, yet there is no ignition, it is a fuel problem (no fuel is being sprayed into the combustion chamber). I agree with Jello2594, it probably is a fuel pump/fuse problem. Or, it could even be a fuel line problem. Good luck with fixing the car.
Regards
