S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Wheel Help
Old Feb 28, 2006 | 07:31 PM
Harpov's Avatar
07 C230 Sport, 97 C280 Sport
Red face Wheel Help
WHEEL HELP?! im trying to run a 16 inch wheel on a 86 300sdl. The wheels are amg monoblocks. 16inch and 7.5 wide. the tire size is 225/55/r16. They rub in the front on the inside. what solutions do i have? can i get around this? what are my options? spacers? help please....
Old Mar 1, 2006 | 02:27 PM
Hattaresguy's Avatar
1987 300SDL aka the "Money Pit"
Well I currantly run the same size wheel and tire combo on my SDL. So the problem is the offset.
Cheap spacers on a MB are nothing but trouble, and can be down right dangerous.
http://www.hrsprings.com/site/index.html
This style of spacer is the only kind that should ever be used on a MB. The downside is that the wheels may stick out past the fenders giving that cheap riced Honda look.
The better solution is to sell those wheels and buy the right ones.
Look for the offset number on the back. I *THINK* w126's need about an ET34 but I am not sure don't quote me on that.
Old Mar 1, 2006 | 02:34 PM
Harpov's Avatar
Question
thanks for replyig. do they stick out on yours? so this is the safest way to go either the spacer you recomeded or buy diff wheels?
Old Mar 1, 2006 | 02:36 PM
Harpov's Avatar
Red face wheel help
but there guys on www.benzworld.org running 18 and 19 and even wider tires? how they doing it?!
Old Mar 1, 2006 | 02:53 PM
ken_xman's Avatar
SAFE SPACERS. And yes I use them. No other affiliation.
www.gilracing.com
Old Mar 1, 2006 | 05:33 PM
I bought wheels with the right offset, no spacers needed.
Tirerack.com.
Old Mar 10, 2006 | 11:43 PM
jjay911's Avatar
1991 300sl 5 speed manual
any rim will fit
as long as its from an s class mercedes or sl mercedes from 1983 threw 2006. Everythink is the same. Just look at my 87 S class limousine with rims that I put on it from a 2003 sl 500 convertible. No spacers were needed however i put very small 1/4 inch ones on the back to bring the wheel out a little bit. Jeff
http://www.benzworld.org/gallery/sho...ame=_Limousine
Old Mar 11, 2006 | 08:05 PM
No they are most certainly do not. W140's use different lugs and tire size. R129's use a completly different offset. It cost me an afternoon spent picking up wheels off an SL500 and $200 to figure that out that hard way.
R107's may bolt up not sure. I *think* most of the stock wheels offered on the W220 will bolt on.
You really need the offest to determine if a wheel will fit.
Old Mar 16, 2006 | 12:50 AM
jjay911's Avatar
Ok that makes sense
I suppose that makes sense because I took wheels off the 03 sl Convertible as pictured and put them on my 126s class. I did not know the regular S class wouldng fit like a 140.Thanks I learn something new eveyday. JJ
