S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Need help with Check Engine Light
Old Mar 4, 2006 | 08:59 PM
bob15489's Avatar
The check engine light is on on my 1991 300SE. How do you read the codes out of the ECU and what equipment do I need. I'm assuming this car is pre-OBD so a scanner won't work. I'm new to MB but I do have a lot of experience working with fuel-injected cars. Any help would be greatly appreciated. Thanks!
Old Mar 4, 2006 | 10:56 PM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
Maybe there is some vaccume leaks somewhere? Do you work on your own car or take it to a mechanic? I use a generic MB mechanic in town.
Old Mar 10, 2006 | 08:38 PM
bob15489's Avatar
It's not a vacuum leak. I generally work on my own cars (I used to build turbo 4-cylinder engines and old american V8s). German engineering is soooooo different than what I'm used to. I figured out how to pull the codes and reset them, but I keep getting the light back on for the same thing. Apparently it's code 9 and 17 (O2 sensor and EHA voltage). I replaced the overload voltage relay to no avail. Please anyone help!
