S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
84 500 sel light rheostat replacment
Old Mar 30, 2006 | 04:41 AM
convert's Avatar
84 500SEL 76Moto Guzzi w/Sidecar
I need help with the rheostat replacement, I have the cluster out but how do you get the stat off?
any help ,,, Thanks
Old Mar 30, 2006 | 09:08 AM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
I think you unscrew it from the back, no?
Old Mar 31, 2006 | 02:48 AM
convert's Avatar
Thanks DTKW, found the screw and removed the rheostat. This is what happens when you don't remove the steering wheel... Convert
Old Mar 31, 2006 | 08:26 AM
dtkw's Avatar
I believe all you need to do is move the steering all the way to the back, there should be enough room to pull the cluster out.
Old Mar 31, 2006 | 11:11 AM
convert's Avatar
DTKW, Thanks for the info, any advice on trouble shooting brake light on, I checked the fluid level and the parking brake is ok, car sat for a years, should I bleed the system, check the 'low fluid' sending units or try and locate the parking brake engaged switch. Convert
Old Mar 31, 2006 | 11:35 AM
dtkw's Avatar
Which brake light? Parking brake or the brake pad warning light?
Old Mar 31, 2006 | 07:17 PM
convert's Avatar
Parking brake, the system is working but the light is on, is there a reset switch? at the master cylinder or the parking brake pedal.
Old Apr 1, 2006 | 07:06 AM
dtkw's Avatar
Or the parking brake cable? Might need adjustment?
