S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Help Removing Sunroof Motor on 420SEL
Old Apr 1, 2006 | 08:36 PM
inthemedia's Avatar
I need to replace the sunroof motor on my '86 420SEL. The question I have is: How do I separate the guide tube that the sunroof cable goes through from the motor assembly? I have removed the 2 bolts holding the motor to the frame of the car but I can't see what is holding the guide tube to the motor assembly. I have also removed the sunroof headliner to facilitate removing the cable (if necessary) and lubricating the various parts while I'm at it. Thank you.
Old Apr 3, 2006 | 09:51 AM
golfboy's Avatar
89 420 SEL and 97 E320
There is a retainer clip where the tube meets the motor. You may need a flathead screwdriver to remove the clip.
Old Apr 3, 2006 | 11:38 AM
inthemedia's Avatar
Thank You!
