S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Need help please. AC question.
Old Sep 13, 2006 | 12:16 AM
AgieDC's Avatar
Fan blower is not working. Have checked the following.
1. Main fuses not blown in main fuse box front left firewall.
2. Unable to confirm location of any auxilliary fuse to see if blown. I read that a 16 amp blower motor fuse is in line, but not sure where it is, and unable to determine from service manual.
3. Under passenger dash, removed covers and disconnected power supply to blower motor (3 prongs). Tested voltage from pushbutton switch and confirm that power does reach the blower at appropriate voltage ranges for low, hi, and auto fan settings.
4. Blower does not run. If run wire directly from battery to blower, it will run. If run direct hot wire to "red" wire in 3 prong connector under passenger side, keep everything connected together, everything runs fine, even varible speeds of fan blower. What does this mean?
5. How can I test blower, current regulator (N29) to see if working correctly or not burned out?
6. How can I test steps 8 to 21 (p. A29 in Service Manual) if I only have a multi-tester?
Stumped. ANy help is appreciated. Chris
Old Sep 20, 2006 | 06:16 PM
las769's Avatar
1990 300 SEL 1999 420sel, 1999 ML320, 1996 500sl,2001 sl500,1999clk320, 2002 S600
Fuse
There is a fuse holder that is just for the blower motor and it takes
a flat 30 amp fuse. The holder is on the fire wall in front of the brake booster
you will have to look real good because it just look's like a connector with wires coming out of each end. you will have to get fuse from MB dealer
