S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
how do I remove the rear seat?
Old Jan 12, 2007 | 03:18 PM
bcmbcmbcm's Avatar
380 SEL 1982
How do I remove the rear seat? I need to run some wires back there.
Thanks!
Old Jan 12, 2007 | 04:37 PM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
1st the bottom has to come out. It is straight forward. Push the front of the bottom towards the trunk and lift. It is held on the right and the left side.
Once this is removed there are nuts to remove the top seat back. pull the headrests out of the car first, if you have them. The top part of the seat than can be lifted up and out of the car.
Bruce
BENZITCH
Old Jan 12, 2007 | 04:58 PM
bcmbcmbcm's Avatar
380 SEL 1982
where???
Bruce
BENZITCH
where exactly do I push and lift?
Old Jan 12, 2007 | 11:39 PM
bcmbcmbcm's Avatar
380 SEL 1982
I tried it
I tried to push and lift but nothing happened...maybe I am not pushing in the right place? Will I hear something release when I push?
Old Jan 14, 2007 | 05:28 PM
Dawson AMG's Avatar
2013 E63 AMG
Open rear door at corner of seat base place your hand and slide it around to the center of seat slowly you will feel a small latch push to middle and pull up on seat. Do the same on other side and remove seat bottom then remove 2 10mm bolts at both side bottom of seat back remove. Install in reverse.
Old Jan 15, 2007 | 01:07 PM
bcmbcmbcm's Avatar
380 SEL 1982
ok like a hidden lever?
so run my hand around the bottom edge and feel for a hidden lever, then pivot it towards the center? Will it pivot back towards the center or forwards towards the center. This will be a huuuuuge help.....to get the seat out. I can then run wires front to back and get my drivers seat back in.
Old Jan 16, 2007 | 12:23 PM
BENZITCH's Avatar
Sorry forgot to mention those orange/red tabs thqat need to be slid.
Old Jan 16, 2007 | 12:25 PM
bcmbcmbcm's Avatar
380 SEL 1982
what the h&&&
Guys I looked around and I don't see/feel anything that looks close to what you are describing. Any way to help me out with a pic
