S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
300se
Old Feb 26, 2007 | 09:51 PM
Mb56091's Avatar
1985 Mercedes 380se
300se
With a 300se is the engine still good at 200000 miles. How much should the car be worth with this mileage?
Old Feb 27, 2007 | 07:06 AM
luda's Avatar
ML 320, 1998
This will depend on the way it has been driven & the service it have received. Also the climatic condition.
I overhauled mine at 250 000 km. Lots of high speed high-way and rapid accelerations. I will consider that very good, taking the hard use it have received.
Started to use a lot of oil.
Main reason was valve guides & worn piston ring grooves.
200 000 miles are approx 300 000 km, so you might need a engine overhaul soon.
You might also get a lot of answers claiming more than a mill miles, however, that might only be the very lucky & careful ones.
As for the price, not a clue about US value.
Per.
