S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
300SD Master Cylinder replacement lost vaccum
Old May 2, 2007 | 11:11 AM
Rich Ackerman's Avatar
Unhappy 300SD Master Cylinder replacement lost vaccum
I just replaced my brake master cylinder after starting up the car 1. there is no power assist to the brakes. 2. When shutting off the car - it still is running and have to hit emergency stop to shut it off. Thinking the vaccum booster was the culprit I replaced it and still have the same problem. When I disconnect the main vaccum hose from the booster, there is vaccum and when I "plug" it it shuts the car off. Need help this is my main mode of transportation. btw I have checked all other vaccum connections and they are good.
...rfa
