S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
is it an engine failure or what ?
Old Aug 6, 2007 | 05:44 AM
handling's Avatar
hi guys
my 280SEL done 155000 KM only
actually i put mobil1 fully synth oil and a problem of low oil always here since i put mobil 1 may be due because it is more lighter
anyway when i rev my engine and enter the red zone the car produce a white smoke
any idea?
Old Apr 1, 2008 | 09:39 PM
Untertürkheim's Avatar
What weight oil are you using?
Old Apr 2, 2008 | 11:54 AM
RogerJones's Avatar
1996 W124 E320 Coupé, 1990 W124 300E twin turbo, 1991 W126 300 SE, 1984 Ford Capri 2.8i
White smoke is a sure sign of water getting into the combustion process, isn't it? You may have a head-gasket problem.
Old Apr 3, 2008 | 03:57 AM
morris374's Avatar
1991 420SEL & 300E, 2003 BMW X5, 2001 740iL all on DUBS
yea check the head gasket and u probably should try to keep the car out of the red line there's a red line there 4 a reason
