S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
85 380 SE - interior function
Old Nov 2, 2007 | 12:36 PM
eloc206's Avatar
1985 380SE and 2007 GL 450
steering wheel horn isn't working any ideas of what could of caused this problem..
also..
heater unit is constantly blowing out hot air even when temp setting is all the way to cold..
car has 105k miles, any experience else out there with these problems? if so what did you do to fix these problems... thanks
Old Nov 18, 2007 | 10:49 AM
RichardLSU's Avatar
1985 300SD
check your fuses.
Old Dec 5, 2007 | 11:36 AM
hineywineries's Avatar
It changes all the time
For the heater you might try pinching the cotacts together at the mono valve. MB uses a fail safe system on the heaters. If you lose 12 volts to the mono valve, you go to full heat.
