S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
90 300se shift problems
Old Dec 13, 2007 | 01:12 PM
Morganvalley's Avatar
1990 300se
Question 90 300se shift problems
My 90 300DSE suddenly stopped shifting into 4th gear, also sometimes does not shift from 2nd to third, but can usually be made to shift (2 to 3) by stopping and restarting, A possible related issue - at the same time a catch developed when moving the shifter from drive to reverse but can be worked out by sliding the shifter back and forth through the forward gears a few times linkage appears ok - new bushing installed - Car has 260k mi but a factory rebuild trans was installed about 80k mi ago. No slippage is evident. Any thoughts? Thanks
Old Dec 14, 2007 | 01:34 PM
124-Fan's Avatar
Mercedes Benz
Replace fluid and filter ! And see what happens.
cheers,
Old Dec 14, 2007 | 11:29 PM
1990 300se
This has already been done - Thanks
Old Dec 15, 2007 | 04:12 AM
124-Fan's Avatar
Mercedes Benz
Yes ok. Just a thought.
-I would think your car has the good old 722.300-series transmission, where no electrics are involved, so to speak. Sounds like a stuck valve or something in your valve vody. Perhaps a bad governor. - The linkage might also be out of alignment somehow, since the shift lever is behaving this way.
Cheers,
Old Dec 16, 2007 | 02:16 AM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
Sounds like shifter bushings.
Old Dec 19, 2007 | 11:10 AM
1990 300se
Smile
Benzitch; I have replaced external bushings, are there internal shift link bushings?
Does anyone have experience with "Importdrivetrain.com" manuals - parts - Additives?
I am pursuing the Idea of a faulty governor or stuck valve - can anyone give me info on gov location and service? Thanksfor your help to a newbie.
Old Dec 21, 2007 | 11:49 PM
BENZITCH's Avatar
Sorry I was referring to the external bushings.
Old Dec 26, 2007 | 09:35 PM
jonnyoutram's Avatar
merc 126 500 sec 1984
this may sound silly because im still learning mechanics and didnt really understand what other ppl were talking about as i have not learned that much yet but i thought i might as well try and help...
my 1984 500 sec has a similar ish problem, today it would not start because of this... there apparently is a switch that determines when the car is in park or drive. my switch has been sticky and because the car thought it was still in drive when it was in park today it would not start.
i have had problems with the car holding low gears and not changing up even tonight, i changed the oil and filter... defo needed but didnt really help.
when i got the car started today it was from pushing the gear lever to the top right and wiggling it, this i suppose frees the switch a bit and then it started.
tonight when it was not changing up past second i stopped and wiggled it up to the top left part of park, then put it back into drive and it solved the problem,
just a thought u might want to try that... sorry for the un professional explanation, hope it could help
Old Jan 3, 2008 | 01:52 PM
1990 300se
Still interested in experiece with importdrivetrains.com - manuals and parts.
I now suspect either the kick down control ( at the transmission, switch at accelerator is disconected) or governor, any info on gov would be appreciated
thanks
Jim
Old Jan 6, 2008 | 02:17 PM
jhodg5kc's Avatar
ON SUSPENSION
Quite a few:)
thanks
Jim
You can also disconnect the electronic kick down on the pass. rear of the trans..single pole connection.
I'm wagering you have something stuck in your valve body..does the car even attempt a shift or does it just sit in 3rd no matter what you do?
Does fluid temp have any effect, ie, more likely to work when cold?
Jonathan
Old Jan 8, 2008 | 01:32 PM
1990 300se
Starts in 2nd then uasally shifts to 3d on rare occasions it suddenly kicks down to 1st - makes for an interesting experience - Hot cold no difference,
if it dosn't shift from 2nd to 3d can usually be made to ny coming to a stop and restarting. I will try Disconnecting the kickdown at the transmission Thanks. Jim
