S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Rusty Fuel Tank??
Old Dec 28, 2007 | 06:30 PM
jonnyoutram's Avatar
merc 126 500 sec 1984
Rusty Fuel Tank??
has anyone ever had a rusty fuel tank problem??
i have a low idle miss fire. the other day it randomly fixed itself??????? 50 miles later it came back!!
could this be a rust in the fuel tank problem?? maybe around the pick up in the tank??
any ideas?
Old Dec 28, 2007 | 11:38 PM
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
any ideas?
I had a 1986 560 SEL (sold this year) and if you look at my posted photos taken from under the car you can see a perfectly rust free fuel tank. I tried to load it up with fuel in the winter to prevent condensation in the tank.
Old Dec 30, 2007 | 05:11 AM
kellerboy's Avatar
mercedes 300sd , 380sl , s500 Ford f250 , escort , aspire . volvo 240
is not the tank. may the wire .
Take a plier, let engine running, pull one wire off and hire if the engine gets Worse put it back.try next wire ,if the engine sound the same.probleme found.
Be careful high voltage
don`t worry you don`t die on it ,if you Touch it
Old Jan 12, 2008 | 08:21 AM
i have checked the ignition side and everything is working, i think its the fueling. i have new injectors and fuel filter it might be the fuel distridutor but i dont know what to do with that???
its really strange sometimes it clears up but then 30miles later comes back, thats why i thought it might be a blockage... and their was rust and condensation on the inside of the fuel cap!!
when the misfire happens, at idle, the oil pressuer flutters at 2, when the problem fixes itself the pressure is constantly at 3 at idle...??? what should it be at, at idle???
thanks people
Old Jan 13, 2008 | 06:12 PM
novone's Avatar
420sel 500sel
I think I'd try the fuel filter (by the pump) first then maybe the pump and or the relay in the fuse box.
Old Jan 13, 2008 | 08:45 PM
already done the relay and filter... what u mean the pump might not be putting out enough pressure??
