S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
thud from transmission
Old Jan 14, 2008 | 07:45 PM
jonnyoutram's Avatar
merc 126 500 sec 1984
anyone know what is happening when occasionally you get a it of a thud and jerk from the ca changing gear, its only when your driving a bit harder than usual, as if the gear box sort of takes time to catch up with the cars momentum and then thuds as the gear engages??
any ideas..
sorry for posting so much... i'm just having so many problems....
thanks
Old Jan 20, 2008 | 02:51 PM
jhodg5kc's Avatar
ON SUSPENSION
Quite a few:)
when was the trans serviced last? Correct fluid level? What shape are your flex discs?
Jonathan
Old Jan 21, 2008 | 09:36 PM
Jonathan
just changed oil and filter on the box... where do i find these flex disks?
Old Jan 21, 2008 | 10:27 PM
jhodg5kc's Avatar
ON SUSPENSION
Quite a few:)
The large rubber disc @ the rear of the transmission, connecting it to the drive shaft, as well as one @ connecting the drive shaft to the differential.
Jonathan
Old Jan 23, 2008 | 08:47 PM
Jonathan
cool thanks i will check them, i know what u mean i think my mum's old bmw just had that done.. thanks dude
Old Feb 20, 2008 | 09:52 AM
cruiser's Avatar
1985 380SE
Just to add my 2 cents.... I thought there might be a problem with my transmission when I first got the car as I was not used to the heavy, delayed shift. It is, as you describe, as if you have to wait for the shift and then the car lurches into gear. I can prevent it if I take my foot of the gas and let the transmission shift. In fact if you accelerate slowly it can be very smooth. I had it checked and was told that the transmission is healthy and that this is normal for my car. I was happy to learn that I would not need a repair and I am no longer worried about the transmission failing during acceleration.
Old Feb 20, 2008 | 12:21 PM
Untertürkheim's Avatar
It may also be the transmission and/or motor mounts. My SEC is currently having those replaced (along with a hundred other items).
Old Feb 20, 2008 | 04:11 PM
thanks of the input ppl
