Weird problem with heating system
With my 1990 300se, you can set the heat on "econo" and it seems to work fine, including when you change the temp setting up and down. Here's the problem.
When you change from the "econo" to say "defrost" it starts to blow cold air, if you go back to "econo" it blows cold air. If you turn off the car and turn it back on, it works correctly again. If you turn the car off, set it on defrost, turn the car back on, it blows hot air. like it should.
It appears by turning the car off and back on it resets something, any ideas??
Paul Waddell
1990 300se
Front Royal, VA
