Removing Door Handle
94 e320
What is required to remove the door handle from 1 89 560 SEC? Something broke in all the locking links in my door and I am not able to lock my door anymore.
I removed the door panel and everything possible and the only thing left is to disconnect the link that connects to the key drum (The piece that you insert the key in). I found little clips on the inside of the door that seemed to be holding the door handle to the body but I broke two of them trying to gently pull out the door handle. My question is how do we remove the door handle without risking to break the clips holding it on? Are special tools required? Is that a hidden screw I didn't see? Thanks for any help.
2001 E320
I can't help with your question but have you tried posting your question at BenzWord? There seems to be more replies when I post questions in the W126 forum there so maybe you could get some help there...
For example:
http://www.benzworld.org/forums/w126...door-lock.html
For example:
