S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Cannot open the bonnet!
Old Jun 24, 2008 | 11:57 AM
lessteaks's Avatar
Hi all,
My car's a 1984 500 SEC, W126
I've had it off the road for a while and need to replace the battery, problem is the bonnet will not open! When I pull the release in the car the driver side pops up fine but the passenger side doesn't budge. I've tried push/ pull etc. while someone else pulls the release but to no avail.
Any ideas, I'm desperate! Seems such a simple thing but its driving me nuts!
Thanks in advance,
Les
Old Jun 24, 2008 | 03:26 PM
1985mb's Avatar
2012 W212 E350 Bluetec
There are 2 steps
After pulling the release inside the car, you'll have to pull the plastic insert that then sticks out from the grille, and then lift the bonnet/hood
Old Jun 24, 2008 | 03:27 PM
1985mb's Avatar
Btw, most people in the US may not understand "bonnet".... they call it a hood around here
Old Jun 24, 2008 | 06:37 PM
whoover's Avatar
'19 E63S sedan
If I remember right, my '83 had two little release levers inside the front of the hood/bonnet that had to be pushed towards the center of the car after the inside latch was pulled. Are you sure the '84 wasn't like that?
Old Jul 1, 2008 | 02:11 PM
tinypanzer's Avatar
300 Sonderklasse E
Stuck Bonnet
Try squirting some WD-40 into the latch that is sticking. Wait and let it soak in for a while, then try again the techniques you already tried.
Good Luck.
Old Jul 1, 2008 | 02:39 PM
BENZITCH's Avatar
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
Coupes use 2 release points
Sedans use 1 release point
Can you see the cable on the right side? If so can you try and tug on it with a pair of needle nose pliers to relase the other side.
Before doing that close the hood again on the right and than try and open again.
Love my 84 coupe.
