S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
coolant getting low ! 560
Old Jul 6, 2008 | 12:41 PM
560er's Avatar
Hi all
I have 1990 560 euro spec, my problem in short is it loses coolant while running, if in town after around 3 to 5 day's the low coolant light pops up. on high way maybe after 100km (around 60 miles)
i've changed the following:
1- resrve tank cap
2- radiotor
3- thermostat 60c (it's hot around here )
4- water pump
aux fan and fan clutch are ok.
i've filled the radiotor and left the cap open then ran the car and waited to warm up i've notice that the coolant is going up after some time and kept getting up!!
maybe there is a presure biulding up some where ?
one mechanic told me that i need to change the head gasket, but there is no white smoke, no water with oil.
the coolant is getting out throw the cap because i notice the coolant around that area on firewall.
the car is running smothly and accelation is good
should I change the head gasket or am I missing something?
thanks in advance.
Old Jul 12, 2008 | 11:16 AM
DrB300SE's Avatar
1989 300SE
I'm in the middle of changing out my water pump (89 300SE). I used a bottle of UV Liquid ($6 US at parts store) and a standard black light bulb to locate the leak.
Try it, it's easier than guessing.
Old Oct 16, 2009 | 10:48 PM
daniel_pvq's Avatar
560sec 300e
coolant leak
i found the coolant leak on mine (86 560sec euro) in the heater valve solenoid diaphragm. right next to the batery. very easy to take apart and replace that diaphragm.
Old Oct 17, 2009 | 09:31 PM
Berde's Avatar
1987 300 SDL
If the UV light does not show anything, then it could be an internal loss. But, before you replace the head gasket, check the radiator pressure. It should keep around 14 PSI when engine not running. Then, run the engine and if it is well pass that then you have compression from the cylinders getting into the cooling system, which is typical of head problems (gasket damage or cracked head). Not always when an issue with the head arises there is water in your oild or visversa. When the thing escalates to that then usually the car will overheat in a matter of hours and will gulp mounstruos amounts of coolant. Snap-on tools makes a very good Cooling system pressure check with diferent adapters to conform to different size necks openings. Hope is just a heater hose gone bad, which is not serious and an easy fix and that my comments show you some light! G.L. with the fix Bud
