S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
where is the 02 sensor??
Old Sep 23, 2008 | 12:32 AM
jonnyoutram's Avatar
merc 126 500 sec 1984
hi, i posted a question about a problem im having with over fueling and black smoke the other day you can see it a few posts down, im just wondering where i can find the sensor on the engine??
thanks
Old Sep 25, 2008 | 06:34 PM
nsmith17044's Avatar
1990 560SEL
O2 Sensor Location
The original sensor is installed in the first cat. element on the passenger side where the exhaust manifold connects. To make the job easier you will probably need to remove the front end support cross member although you probably can do it without. The 84/85 used the single wire / non-wide band O2 sensor that is inexpensive.
If you are having over fueling and black smoke it is probably not the O2 sensor.
