S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Fuel Distributor
Old Sep 2, 2009 | 06:06 PM
Alford's Avatar
1990 560 SEL
Fuel Distributor
I have a 1990 560 SEL with a misfire.
(Passenger Side 3rd Cylinder from the front)
There is no fuel leaving the port on the fuel distributor that supplies the injector for that particular cylinder.
The other ports on the fuel distributor are fine.
Any tips on what I should do next?
Alford
Old Sep 3, 2009 | 05:12 PM
Alford's Avatar
1990 560 SEL
Has anyone ever opened up one of these fuel distributors? I guess there is only one way to find out whats inside!
Old Sep 6, 2009 | 01:25 PM
jhodg5kc's Avatar
ON SUSPENSION
Quite a few:)
they're not terribly user serviceable.. Did you pop the line w/ the car running? You might also try jumpering the fuel pump relay and depress the air flow plate, see if fuel comes out of the suspect port...
If that doesn't work, CIS Flowtech make the dist. of choice..I can help you source one FWIW.
Jonathan
Old Sep 7, 2009 | 10:52 AM
Alford's Avatar
1990 560 SEL
Thanks for the reply. I did pull the line out of the top of the fuel distributor while the car was running, and no fuel was coming out of the port.
I was about to take the top off the fuel distributor to see if there is a passage I can clean out, but I wanted to check online first.
How would jumpering the fuel pump relay make a difference? I am getting fuel out of the 7 other ports. And when you say "air flow plate" do you mean the big round disc that opens to let the air in?
Thanks!
Old Sep 7, 2009 | 12:31 PM
jhodg5kc's Avatar
ON SUSPENSION
Quite a few:)
Yes, I'm aware. I'm just telling you the actual procedure for verifying that it Does Not Work.
Yes, the air flow plate is the big round disc..
I would Not fiddle about in the FD w/o knowing what you're doing.
Jonathan
Old Sep 9, 2009 | 12:29 AM
d2007k's Avatar
300se
id say before you crack open yours .. go to a bone yard and pop one of them open first .. that way you know what your getting yourself into .. if you do be sure to take pics and let us know how it goes
