86' 420 sel rotor + rear shock replacement, any tips?
Subscribe
Mar 31, 2010 | 12:56 PM
so i just bought some rear bilstein shocks HD's and four brembo rotors... anyone got any tips on removal and installation..
Reply 0
Mar 31, 2010 | 11:24 PM
I just did mine last weekend. It was actually quite easy with the help of a friend. Did all four shocks in less than an hour. The toughest part was unscrewing the two nuts that lock together on top of the shock. It was useful to have a thin 17mm stubby open end wrench to hold the bottom nut. It was just an awkward position to be in holding the wrenches. My buddy helped by holding the screwdriver on top so the shock shaft would not turn. No advice on rotors...haven't done those yet.
ha, just noticed, first post. I do most of my posting over at benzworld,0RG.
Reply 0
Apr 1, 2010 | 02:05 AM
cool thanks man
Reply 0
Apr 4, 2010 | 07:19 PM
rear rotors are stuck...
sry guys this is the 1st time i will be doing this on my 420 and i cant seem to get the rear rotor off.. i took off the caliper and the allen screw off of the rotor but the thing wont budge.. i sprayed pb blaster/ hammered it-- no success.. any Help please?
Reply 0
Apr 5, 2010 | 11:03 PM
where did u get the brembos, whats the model number
Reply 0
Apr 25, 2010 | 02:24 PM
did you try backing off the parking brake?
Reply 0
May 20, 2010 | 02:51 PM
mine were stuck too. get a mallet out and go to work!
Reply 0
May 20, 2010 | 09:42 PM
2 pound short handled sledge hammer. Hit it hard! Both ways - toward the axle and off the axle.
Reply 0
Explore
Jul 13, 2010 | 08:39 PM
'99 S420 - Rear rotor removal
I agree, "2 pound short handled sledge hammer. Hit it hard!" This is just what I had to do after using three different types of penetrating oil. Job is all done, overdue by three weeks.
Thanks guys.
Reply 0
Jul 14, 2010 | 01:54 PM
yeah, i finished it awhile ago so to leave so abruptly, i used a hammer and some PB blaster got them off, eventually i had to take a grinder to it and remove the rust where the rotor meets the hub as it was causing my rotor to be offset, i had to reset the parking brake and after that it was done. i didnt end up doing the replacement on the shocks seeing as how they really weren't leaking..
Reply 0
Subscribe
Currently Active Users (1)
