S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
heating system
Old Jan 7, 2011 | 11:38 AM
harlan's Avatar
420sel
heating system
drivers side feet does not get hot air
Old Jan 19, 2011 | 10:13 PM
aduhaime2003's Avatar
300sd
I am trying to get info on the same problem. However, i do not have heat on either side. I do not understand the climate control system at all. I guess it is because i have never owned a car with a climate control system. I am used to being able to select the vent I want. I do not know which button to press to actually be in the correct mode to ge the floor heat to enable. I have however removed the button panel and replaced all the lights with leds and cleaned all the contacts and now the buttons are readable at night I also did the power window buttons. I bought a vacuum tester tonight and last night rebuilt one of the fresh/cabin air dampers with a bicycle innertube (it worked btw). I know I have vaccum to the solenoid bank but I dont know where to go from here.
Old Jan 25, 2011 | 04:07 PM
blowfish's Avatar
81 300sd, 83 300dT, F350, 250 diesel & 16 ft car trailer
the heater core is divided by left & right side. check if other side have heat.
the lower flap can go, so inly heat comes out is windshield vent & or face level.
the mono jet valve can be plugged so no hot water pass thru at all.
U can get new one or toss it out, it has a brass screen if plug nothing will get thru.
