S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Power Steering Pump Disassembly?
Old Mar 13, 2011 | 11:26 AM
RobSaari's Avatar
'89 420SEL
The power steering pump on my '89 420 SEL has a severe leak from the rear cover. It's a ZF pump. Getting the spring clip off was simple enough, but I can't figure out how to get the rear cover off. What's the trick to getting the cover off so I can replace the O-rings?
Old Mar 13, 2011 | 12:59 PM
karwerk's Avatar
14 e63s,03 e55, 69 280s, 92 500e, 95 e320, 08 lancer
Just tap lightly on the back circular cover with a hammer. Its tight because of the seal ring. And hope im correct.
