Need Help Mercedes Benz 2010 C300 (Pulling to the right )
Mercedes benz C300
![Exclamation](https://mbworld.org/forums/images/icons/icon4.gif)
Hello i currently have a Mercedes C300 2010 which is pulling to the right on any type of road, i have already did a 4 wheel alignment at my local Chrysler Jeep Dodge and it failed the alignment so i took it to my authorized Mercedes dealer for another alignment , which still pulls to the right and came with the same previous problem . So i really need a resolution to my problem because its obviously not an alignment or a tire issue because the tires are in great condition. Thank you very much for your time reading my post
1 Post
88 535is, 89 318iT
1. You posted in the wrong forum, so don't expect a lot of answers
2. If you have a problem like this and you've already had two alignments, please post your alignment specs from the print out you should have received. Need to know camber, caster and toe for the front and rear.
3. Swap your front tires side to side and see if the pull lessens or pulls left.
