S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
86 560SEL engine quits
Old Jun 18, 2003 | 11:41 AM
drwharf's Avatar
I have started experiencing a rather disturbing problem. When I am cruising on the freeway the engine will suddenly quit. I pull over put it in park and it will start right up.
Any ideas?
Old Jun 18, 2003 | 05:01 PM
dtkw's Avatar
1986 560SEL, 97 BMW 740iL
A bad fuel pump? or the relay? Check the fuel pump relay to see if it is in working order.
Old Jun 19, 2003 | 09:04 AM
drwharf's Avatar
thank you. I just replaced the relay and we shall see, since this is an intermitent problem.
Old Jun 19, 2003 | 02:41 PM
V12BIGBODY's Avatar
03 S 500--94 BMW 325i--01 GSXR 1000
hey buddy i had the same problem---can't say it will work but get some new cheap plugs in there!--the cheaper the better-
