S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Please help with fuel pump problem Thanks!
Old Jun 10, 2012 | 09:06 PM
carguy2727's Avatar
w126, w140
I have a 89 560 sec. Died while curing down the highway at 55mph. No sing of life from fuel pump, so I changed it with one I took from a 88 420sel that I parted out. I heard the engine in that car run, so figured the pump was good. After changing the car still would not start. So I went to basics, removed air cleaner and powered in some gas. Car stared right up and ran fine until the gas I pored in ran out. So I figured it is a fuel problem. Next I take a battery and some wire under the car and jump the fuel pump. Both pumps work fine with jump. Then I decided to jump the pump that I had just taken out of car, one pump worked fine the other not at all. Yet buy turning ignition key to on position or even cranking engine over the pumps I put on the car are dead as a door nail. I have 2 complete parts car an 86, and 88 560 sel, that ran and drove when I parked them in the back about 8 months ago. I figured it must be the fuel relay, so I will just take one off the parts car and try it. Just one problem. I don't know where the fuel relay is or what it looks like, or any kind of parts numbers to be looking for. Any help getting my baby back on the road, would be greatly appreciated. Thanks! Will PS there is 3/4 of a tank of fuel
Old Jun 11, 2012 | 09:48 AM
lululu's Avatar
94 e320s
The relay is to the right of brake booster,part no 003 545 25 05 or similiar, the one next to it is for ac compressor labeled klima
Old Jun 11, 2012 | 08:04 PM
carguy2727's Avatar
w126, w140
All the thanks in the world to lululu you are a true gentleman and a scalar. once again me and my friends are cruising in my BENZ
