S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
85' 500 sel valve tap
Old Aug 22, 2012 | 12:02 PM
Mblifer's Avatar
85' 500 sel
hello ,
My 85' 500 has a valve tap coming from the front cylinder passenger side. I bought the car at 98k with the tap. I'm at 101k now and did the first oil change. I was hoping the tap was just from sitting. While filling it with synthetic 10/30 I noticed some pitting or slight galling on the tip of the cam lobe right under the fill cap.
Question, is there a valve clearance or " preload" adjustment that can be done?
Is it easy to change a lifter?
Car runs great and it is in exceptional shape. I want to nip this before it's a problem.
Any input is appreciated.
Old Aug 28, 2012 | 11:23 PM
PelicanParts.com's Avatar
SPONSOR
Answer
Odds are 99.9% you need two of these.
One for each cam oiler tube.
They are plastic fittings that fail every twenty years or more.
repair kit
MB# 1161800184
roy@pelicanparts.com
Attached Thumbnails 85' 500 sel valve tap-cam-oiler-repair-kit_aerijhg354.jpg
