S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Picture inside: What is this, should it be so hot?
Old Sep 22, 2012 | 12:26 AM
twinlol's Avatar
W126 500SEL
Hi guys, great forums.
I would have used the search function, but I don't actually know what this component is called!
My car won't start and prior to that it was running very rough, the fuses inside the fuse box have been changed.
My questions are;
In the picture, what is the item labelled 2? It's extremely hot, it gets to this very warm temperature shortly after the battery is connected.
What is item number 3? same problem as number 2.
Also, the pipe circled and labelled 1, what is that? I can't seem to find where it goes, I'm beginning to think it may have snapped and goes far back.
Thanks for your assistance.
Attached Thumbnails Picture inside: What is this, should it be so hot?-whatisthisidonteven_zpsff1735ee.jpg
Old Sep 22, 2012 | 01:45 AM
twinlol's Avatar
W126 500SEL
My questions are;
To answer my own question in case others are curious, 2 and 3 are ballast resistors.
Old Oct 16, 2012 | 11:40 PM
Jimbo Jim's Avatar
pipe 1 could be the power steering return oil line, it should not be so hot.
or am I wong solly.
