S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
85 500sel running sluggish
Old 05-30-2013, 03:50 PM
Mblifer's Avatar
85' 500 sel
Hello all,
Looking for tech advise on my 85 500 again. I recently changed the timing chain, cam gears and upper rails. Here is the situation. Since i finished the job the car now runs and idles smooth , like new but now has no power as in horse power. Running at 65 mph she struggles to keep pace up hill. The best way I can explain is it feels like I'm driving with the e brake on. And forget it if input the air cond on.
Here is the specs I am at now.
Ign timing -TDC set with vac advance disconnect at idle
Cam (s) set at tdc all marks line up ( hand turned and triple checked)
Idle - 500 rpm smooth as silk
Fuel distributed not adjusted
New plugs(Bosch),wires,rotor
87 octane gas with marvel mystery oil
Dash vacume gauge from park to drive is steady with a slight bump going into gear.
I can pedal to the metal and it she feels beyond sluggish.
Any ideas are appreciated.
Thanks,
Old 05-30-2013, 11:21 PM
Elektrische's Avatar
1989 420 SEL
Here are some general things to check...
Be sure the plugs and wires are the correct type for your Mercedes - i.e. Not resistor.
Check for vacuum leaks. The economy gauge should be all the way to the left on the white line at idle (that gauge is just a vacuum gauge).
Then check the Lambda. That is the rich/lean adjustment.
Be sure the vacuum line is going to the EZL and has vacuum (no leaks on the way there). That would adjust vacuum advance and retard for spark.
And check fuel pressure and volume (that it has the flow it should have).
Factory service manual here...
http://www.startekinfo.com/StarTek/o...tedDocId=12253
Another service manual (above shows owner's manual for some cars when you click on engine)...
http://www.w124performance.com/service/W126/Main.html
Old 05-31-2013, 01:22 PM
Mblifer's Avatar
85' 500 sel
Thanks for the links...huge help. I did check for vacume leaks today. Found one on the backside of the manifold directly behind the fuel dist. Looks like a vac dash pot/actuator or something.
Old 06-13-2013, 02:08 PM
Mblifer's Avatar
85' 500 sel
So she won't run now. Just idle. Any throttle and it stalls.
Has developed positive crankcase pressure.
All this has been sudden.
I'm thinking clogged cats? Any ideas?
All of a sudden my Eco gauge is halfway to right. Massive vac leak?
I sprayed all hoses can find a leak.
Advise?
Old 06-13-2013, 05:27 PM
1989 420 SEL
I would do a compression test on each cylinder.
Old 07-04-2013, 11:36 AM
Mblifer's Avatar
85' 500 sel
Compression test done.
152lbs in all eight cylinders, dry
Now what? Fuel system or maybe the mixture is waaaay off?
Stuck egr?
Quick Reply: 85 500sel running sluggish
