S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Shock replacement
Old Jan 14, 2004 | 06:37 PM
speedreamz's Avatar
Shock replacement
I've worked on cars here and there and am mechanically inclined. I have access to a coil spring compressor, jacks and stands. How difficult in regards to access and possible special tools required to replace worn shocks, front and back on a 1987 420 sel. Any feedback greatly appreciated. Thanks
Old Jan 15, 2004 | 08:34 AM
via500's Avatar
First for "shocks" this is for no Hydro.
The backs are easy, you take out the back seat, remove a plastic plug and you can get to the top nut on the shock. The bottom is accessible from under the car. On the fronts the top nut is visible in the engine compartment and the bottom is self evident.
