S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Kickdown button?
Old Feb 7, 2004 | 06:10 PM
MB AMG's Avatar
2002 E55 AMG
Kickdown button?
Where is the kickdown button in the 560SEC because it wasn't working last week. It would stay in second gear when i floored it.
Old Feb 8, 2004 | 02:46 AM
schwarzwagen's Avatar
300SEL
its behind the gas pedal. You should be able to see it straight away if you have a look under there. Its a round switch and has a nice little carrier that holds it in place, there is also a cut out in the carpet for it. Sometimes it can get dislodged from its housing... take a peak.
Old Feb 18, 2004 | 02:05 AM
vdubpower's Avatar
i drive them all, fast and hard
whats a kickdown button????????????
Old Feb 18, 2004 | 05:25 PM
300SEL
kickdown switch
vdubpower,
the kickdown switch makes the transmission shift to the lowest available gear as indicated by the hash marks on the speedo.
Old Feb 19, 2004 | 07:54 PM
MB AMG's Avatar
2002 E55 AMG
It used to work! I'd be going slowly and then floor it, it would shift down to 1st. Now it doesn't work!
