S-Class (W126) 1979-1991: 300 SE, 300 SEL, 380 SE, 380 SEL, 420 SEL, 500 SEL, 560 SEL, 360 SEC, 500 SEC, 580 SEC, 300 SD TURBODIESEL, 300 SDL TURBO, 350 SD TURBO, 350 SDL TURBO
Blower speed and temperature not working correctly
Old May 23, 2016 | 06:33 AM
priedaine5's Avatar
W126 420SE
Question Blower speed and temperature not working correctly
Hi,
I am new to this forum, and tried searching everywhere regarding my problem, but with no luck.
I have to apologize in advance, as I am not a mechanic and understand basic stuff regarding repairing cars.
I own a 1987 420SE, and have a following problem: blower speed at position 1 is reacting as if in position 2. So at position off - it actually turns off, and position 1, blower's speed is as if position 2, at position 2 blower's speed is also as if at position 2 (I hope it makes sense).
Second problem temperature setting seems not to work - always blows hot at feet, windscreen and rear passengers, but cold towards face.
I checked and even tried substituting switches, but doesnt help.
Is it Klima relay or something else?
Thank you in advance.
Old May 23, 2016 | 08:49 AM
priedaine5's Avatar
W126 420SE
Question
Originally Posted by Plutoe
regarding blower speed regulation---that is accomplished via the fan mounted regulator or you have a bad control module!!
Where can I find the fan mounted regulator? And by control module you mean Klima relay?
